I had to find and replace a stand pipe in my carb. It has been a while since I found a new standpipe and got the old one out. Now that I put it back together, does the low speed jet screw all the way up tight, or not tight? Seems like it screws a long way up, like I said it has been while since I took apart and do not remember how far it screws in. Is there a spec on how far to screw it?
Kenneth Hunkins
The open end of the low speed jet needs to seal into the passage. The tapered screw end that is soldered to the tube needs to seal in the carburetor body as well.
So it needs to screw all the way tight even tho it seems to screw a long way up into the body?
Kenneth Hunkins
