#444092 06/18/20 11:10 AM
Bertus Offline OP
Installed grille, rad etc on my '32 car. The fan is quite close to the rad. It's an original honeycomb so I really don't want it damaged! Just wondering what is normal clearance between fan and rad core. I think I have about 3/4".
1932 Chev 5 Window Coupe
Bertus #444097 06/18/20 01:13 PM
The closer the fan is to the radiator core the better the low speed heat transfer. 3/4" is okay as long as the fan does not wobble.
Bertus #444105 06/18/20 04:35 PM
Chipper,
While that may be true, I think poster was asking is whether that distance/gap (from the radiator to the fan) on a 32 is normal, wobbly or not. I sure don't know. The answer is above my pay grade.
I'd bet that Chip knows.
Best,
Bertus #444116 06/18/20 08:33 PM
Sounds about right as it barely leaves enough room to get the belt on.
Bertus #444146 06/19/20 05:19 PM
Correction.
I bet that Steve D knows. Agrin dance
Best,
Bertus Offline OP
Thanks everyone. No fan wobble. So I guess it should be OK.
