Posts: 31 |
Wondering where I might order a new top for my 1926 touring ? Thanks in advance
You will need to find a local auto upholstery shop to fabricate one. There are no pre-made tops for your touring.
Posts: 31 |
Oh ok I see they make one for the 1927 are they that different ? Thanks
Who did you find that makes one for a '27? Once Hampton Coach went bankrupt I was not aware of anyone making interiors or top kits for the older Chevrolets. There are kits for 50s and newer.
Posts: 31 |
Aro 2000 A Division of Putt Georgi Ltd.
Posts: 31 |
He has for 1927 capital tourer If you get a chance maybe google and have a look they appear to make a lot of different tops for older models. See if you think that one may fit mine . I am not sure of the differences from year to year. Thanks
Checked them out. Interesting array of tops they produce. Did note that there was no return on pre-'61 tops so making sure they have the correct patterns is wise.
Maybe you can get dimensions to compare with the top assembly and body size on your '26 Touring. If they match the top should as well.
Posts: 31 |
That’s a very good idea I will do that and measure things out Thanks for your time ....again ...haha
Posts: 31 |
He has no top measurements does anybody know if 26 and 27 use the same top irons ? Thanks
