#443294 05/29/20 05:16 PM
mikeo Offline OP
Does anybody rebuild or sell the kits for the 1932 Trumpet horns?
Housing bolts also?
Thank you,
mikeo #443298 05/29/20 07:11 PM
I bought some trumpet horns for my 1934. They didn't work. I bought a few "donor" and swapped out the motors. Mine were K-26 Delco. Others types may fit. These horns are simple and usually need to have the contacts cleaned and the tone adjusted. The condensers often go bad. I found that .47 condensers work fine. Good Luck
