#442907 05/19/20 11:20 AM
cabboy Offline OP
This is a spec I have not seen or found yet. I am installing a reground camshaft with a new thrust plate and new gear. Should there be a clearance left between the thrust plate and gear when the new gear is pressed on? It seems like if just pressed till tight the new gear will pinch the thrust plate. I would expect a couple of thousands at least to allow oil to lubricate. Anyone have any input? Thanks.
.My 1934 shop manual says free fit to "003.They describe free fit to be turns with no effort and no clearance felt..
cabboy Offline OP
Thank you. That sounds about what I would expect.
