#442332 05/06/20 07:20 AM
IRR96 Offline OP
good morning,i removed my transmission in my 1946 gmc 1/2 ton that I just bought a month ago to replace the flywheel ring gear,want to change the trans and rear end oil,its a 3 speed trans and 4.11 rears,i,m hearing 90wt mineral oil for trans and 90 wt multi purpose gear for the rear,is this what everyone recommends ?
william a gove
IRR96 #442333 05/06/20 07:30 AM
Just put 90/140 in both.
IRR96 Offline OP
thank you,would synthetic be be better ?
william a gove
IRR96 #442369 05/06/20 08:16 PM
No but it will cost more. It may provide you with a sense of well being but the transmission and differential could care less if it's synthetic or not. They got no money.
Best,
IRR96 #442370 05/06/20 08:32 PM
While the synthetic oil does have some benefits over conventional oils you most likely will never put on enough miles on the 46 to notice any.
IRR96 #442379 05/06/20 10:26 PM
iagree
IRR96 #442435 05/07/20 10:35 PM
Make sure it says it is ok for yellow metal. Brass synchro's.
