Hi
i have a 1947 stylemaster with drum brakes.
This weekend my brakes went out luckily I had fixed the e- brake a couple of days before.
After diagnosing the front passenger wheel cylinder went out so I ordered new cylinders for the front a well as hoses and wheel seals so I can repack the bearings.
I would like to install a dual master cylinder with a brake booster
I found this but want to get options for something that will work
https://www.ebay.com/itm/1937-1948-...7-DUAL-BOLT-IN-FRAME-MOUNT-/400293690180any help is appriciated
thanks
augie
