Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
The drivers window on my 46 has been steady going down further, when I close the door and now it just about goes all the way down. Any one know the fix?
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
My 1st guess (and that is all it is), have a look at the clock spring in the mechanism as it most likely broken. Tony
Posts: 1,411 Likes: 7
Posts: 1,411 Likes: 7 |
The window regulator needs inspection, maintenance and as Tony suggested the spring likely needs replaced. I had to rebuild these on my ”˜46 during its recently completed restoration. Nearly complete disassembly of the door components is necessary to accomplish the task, unfortunately.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
Keith, I have an assortment of those clock springs. If you need one, or two, I might be able to help.
Thanks for the replies. Figured that was the problem. Mike I will keep you in mind.
