I recently completed restoration of a ”˜46 Chevy 1/2 ton. The side scraper window seal replacement was a memorable challenging task for the frame- up restoration. Along the way I learned there is a significant difference in replacement parts quality, especially the rubber products. Steele Rubber consistently had superior products.
The task it self required the removal of the inner door skin. The channel that houses the rubber seal must be opened, carefully to remove the old seal. This is a labor intensive task by itself. The channel then needs to be thoroughly cleaned. The replacements seal needs to be slipped into the channel, actually more difficult than it sounds, using a liberal amount of soapy water, plastic prying tools of various shapes and lots of patience. Then, the channel needs to be re-crimped to hold the seal in place. I used a thin wide blade screwdriver and sheet metal pliers that have flat jaws and a straight and flat nose about 0.5”” wide to open the channel and later to re-crimp. The plastic prying tools are/were a Harbor Freight kit. The pliers might have come from there as well, I can’t recall with certainty.
The product referenced in your message I am certain, from my experience, will not work. Did not try them, but from the photos they seem certain not to fit in the channel.
Good luck!
