#441597 04/21/20 08:11 PM
SS_ENG Offline OP
Replacement frame I have a rust free frame but have noticed small diff to orig idler arm attachment orig vertical one bolt through frame tube new frame has two bolt horizontal attachment also rear cross member over rearend seams different all other critical measures look good so far anyone know what frame I have ???????
The 1965 and 1966 impalas used an idler arm with the vertical through bolt and Nut on top of the chassis. The 1967 to 1970 chassis used a different drag link and idler arm which bolted sideways through the chassis rail.
The Rear axle trailing arms are also different on 1967 onwards, with shorter upper trailing arms and different arcs of travel. the 1965 rear axle also has different trailing arm mounting holes. best to keep all parts that came with your new chassis.
Convertible frames also have an additional body mount on the chasis, and stronger side chassis rails.
JACK
SS_ENG Offline OP
Thanks I just hope I can make this frame work I have most all arms and hardware it is a boxed frame [ conv.} so I'm hoping had already blasted and paint 4 years ago before i realized diff
Three different companies made frames for Chevrolet in those years. But all things that attached were the same.
