Posts: 394 |
My '64 Malibu SS 327 has exhaust headers. I want to replace them with original manifolds. I can buy reproduction original style manifolds. But when I search for manifold bolts it offers "rams horn" manifold bolts. First question: Were rams horn manifolds original equipment on 1964 327s? I have a 1976 350 with rams horn manifolds. Second question: Will the rams horn manifolds on my 350 fit on my 1964 327?
See the USA in Your Chevrolet
1932 5-Window Coupe 1935 Sedan (streetrod) 1955 Apache 1955 Nomad Two 1956 Nomads 1959 Apache 1964 Malibu SS Convertible 2012 Corvette Grand Sport
James
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
rams horn manifolds first appeared in 1956. generally speaking, there were 2" outlet and 2 1/2" outlet manifolds of the rams horn variety. most dumped straight down to mother earth, and some went down and back at about a 45 degree angle. the repo manifolds, at least those sold by the corvette dealers, are very easy to differentiate from originals. determine if u need the 2" or the 2 1/2 " manifolds and get back with us. mike
Posts: 394 |
Mike, thanks for the response. Things have changed since my original post. We tore the 327 apart and found everything inside broken. Valve spring broke, cam worn out, crank shaft scarred, block cracked, one head cracked. Long story short, we're putting the 350 in the Chevelle. Now I have to determine if the exhaust will clear since the rams horn dump out in the center. I'll post an update on that when I find out.
James
Posts: 394 |
If you're interested in this post check the "Building an engine for my Malibu" thread under What Did You Do With Your Car Today.
James
