#440957 04/10/20 09:59 PM
Jim157 Offline OP
Looking for a replacement oil distributor housing for my 224 cid 1922 FB series 50 car and a clutch release bearing. Would like to get the baby running again
James Gardner
Become a Member!
Contact Gary Wallace in St Louis, MO and Bob Marx at Marxparts in Wisconsin. Google search will get both of them for you.
Jim157 Offline OP
Thanks for help I’ve been at a loss with this!! Jim
James Gardner
You might want to look at trying to find a 4cyl Oldsmobile oil distributor,or at least a picture of one,as the 2 engines are nearly the same,and maybe the Olds oil distributor will be the same.
CJP'S 29
Jim157 Offline OP
Thank you for the info Jim
James Gardner
Jim157 Offline OP
No luck with Gary W or marxparts. Any more leads or suggestions needed
James Gardner
