Charlie, I have known, and used, D&M Restorations in Greenville, S.C. for over 25 years. My personal opinion is they are a little pricey but darn good.
The great thing about it is D&M is only about 25 miles from me.
1937 Chevy 1/2 ton Pickup 1950 Chevy Styleline Deluxe Coupe 1953 Chevy 1/2 ton Panel Delivery
I'd rather walk and carry a Chevy hubcap than ride in a Ferd.
Just a note to say that it's fairly easy to change a poor or incorrect color face on an otherwise working gauge. Grind off the rivets from the back side and remove the face. A better looking face can be installed using short lengths of the correct diameter electronics solder as replacement rivets. Peen the solder from both sides. The peened ends are hidden behind the dash gauge bezel. I think I have used .032" solder.
Neat trick with the solder "rivets"! Easy to get material, does not take much force to peen them, and more than strong enough for this application. Thanks!
