#440727 04/06/20 10:52 PM
davids Offline OP
Hello: I have a 1929 stock Chevy and the temperature gauge seems to not work! I would like to ask all the persons that have had the problems I have ,to tell me how to test the system to see if it is the gauge or the sending unit! Do I ground the wire to the gauge or engergize it to get a reading??
ANY help,advice,suggestions or technical date(OHMS) readings voltage feed back--etc will help.
email---dhouston66.dh@gmail.com
828 645-0649 any time!
davids #440735 04/06/20 11:29 PM
The August and September 2014 G&Ds have an article that describes this electric heat gauge system that was used only for that one year.
davids #440753 04/07/20 11:52 AM
Make sure you have a good ground connection. Billy Possum has the sending units.
http://billypossum.com/C&P_Catalog/C&P_Catalog.htm
