Posts: 87 |
Does the speedo gear come out of the left side of the trans or must you disassemble the back end of the trans?
Dale Duffield Tulalip, WA. 1927 Sports Cabriolet (since 1954)
Redracer, One half of the speedometer gear set can be removed without taking the transmission or u-joint apart. The other gear is pressed onto the front of the u-joint which must be removed by taking the u-joint apart and then from the back of the transmission shaft.
