Posts: 234 Likes: 5
Posts: 234 Likes: 5 |
I put the new pump in when I was building the engine last summer. Seems it lost pressure as the engine ran over a few weeks. Something came loose or clogged I think. The pump is working enough to fill the oil filter though. But I'm sure not content with the 7 pounds it puts out going down the road. Roger
My thoughts are the crap in the pan cause the pressure relief valve to hang-up.
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
In an earlier post I suggested the same point that Gene noted. There is dirt holding the distributor valve open.
Even though it is a new oil pump it would be the second place I would check. By now probably some of the crap in the pan is stuck in an inlet passage or has made the relief valve in the pump stick open.
Posts: 234 Likes: 5
Valid points from you two. I'll follow that those considerations as soon as I can. Next couple of days will be spent smoothing hog holes in pastures. They were busy this winter. I'll let you know what I find. Regards, Roger
