#440008 03/23/20 06:23 PM
I have a metal tire cover in good condition. I would like to know the best way to remove the stainless steel trim ring on the front. I don't know how hard the clips are to find. Don't want to ruin them.
You're talking a 34 Master, right? The Trim Ring is easy to remove. Simply use a small flat bladed screwdriver in the slot in the clip and turn either way, 1/4 of a turn. Usually the clips don't brake. I had several sets of clips but sold the last set over the weekend. I may be able to get some more, don't know. You will probably never find any clips so save the ones you have.
Jon T.
Thanks Jon, much appreciated.
Frank
