#439339 03/06/20 10:15 PM
Hi, Was advised to try this forum since these are electrical and 6 volt. Can anyone tell me what these fit? Thank You, Doc
1928 2dr Coach
1930 4dr Sedan
1930 3 window Coupe
1937 4dr Master Deluxe
1941 Special Deluxe
1946 Willys
1946 cj2a
1953 2dr 210
DocHarley #439344 03/07/20 12:47 AM
Your lamps look like the park lights from sealed beam replacement headlamps. The horns could be a genuine accessory or an aftermarket enhancement to factory horns. Look for a brand name like Delco Remy, Autolite, Spartan.
35Mike #439383 03/07/20 11:14 PM
Thanks for the reply Mike, After a closer look they say Spartan, Do you have any idea what they fit?? Took the round caps off end and they look brand new inside. They work. Heres a better look at the tag on the heater, Thanks Doc
1928 2dr Coach
1930 4dr Sedan
1930 3 window Coupe
1941 Special Deluxe
1946 Willys
1946 cj2a
1953 2dr 210
DocHarley #439390 03/08/20 04:55 AM
That is a 33 heater.
devil Agrin
DocHarley #439423 03/08/20 10:33 PM
Thank you Antique Mechanic for the info. I will list it in the for sale forum as heater for 1933 car or truck. Thanks again, Doc
1928 2dr Coach
1930 4dr Sedan
1930 3 window Coupe
1941 Special Deluxe
1946 Willys
1946 cj2a
1953 2dr 210
DocHarley #439436 03/09/20 01:34 PM
Doc,
I don't know Spartan horns were OEM equipment for anyone. They might be aftermarket items.
Heaters similar to yours were used through 1935. There are at least 2 designs of the cutout in the top. I'll check my '35 Accessory Catalog and look at the photos.
Ray knows his stuff. Could be '33 only.
DocHarley #439485 03/10/20 04:02 PM
I'll have to look thru my files but the horns look very similar to a set I sold a number of years ago. The picture was of a truck with those type horns and bracket. Out of town til Sun but will look when I get back.
nhinchas #439498 03/10/20 09:19 PM
Thank you all for the replys, I knew someone at this site would know something . Meanwhile , my wife will help me search internet too, I,m not good at this computer stuff. Thanks again Doc
1928 2dr Coach
1930 4dr Sedan
1930 3 window Coupe
1941 Special Deluxe
1946 Willys
1946 cj2a
1953 2dr 210
DocHarley #439728 03/16/20 06:49 PM
Doc,
I finally checked my 1935 Accessory Catalog. The cutout design for the '35 heater is different.
35Mike #439733 03/16/20 09:14 PM
Mike,
Would you know what year this heater is for? This is a water heater. The one that originally came with the car was a gas heater. It had a metal tube that ran from a plate under the carburetor to it and there would be a flame inside the heater and the fan would blow the warm air. I don't really need a gas fed flame inside the car for heat. LOL! BTW I have a 35 Standard Coach. I am going to use this one in my car. I also have another identical one and the old gas one on my shelf.
Thanks,
Pete V
Heater 1-Before.jpg Heater 2-Before.jpg Heater 3 - Before.jpg Heater 4 - Before.jpg Heater1 - After.jpg Heater2 - After.jpg Heater3 - After.jpg Heater4 - After.jpg
PeterV #439783 03/18/20 01:01 AM
My 48 has a gas heater, made by Southwind. It wasn't hooked up and I never did hook it up. It doesn't get that cold here in Napa. But if I drive in the winter, there is so much heat coming through the firewall that I keep warm. Seems like I take it out in the summer on the hottest days we have.
