Along with the repair manual it will be helpful to have the brake adjusting tool to set the cross shaft at the correct angle. I believe it is available from the Filling Station. Adjusting the pull rod to the proper length is simplified with the tool. The pull rod connects the pedal to the cross shaft. No need to remove the drums to do the adjustments but if you have no idea of the condition of the internal brake parts then I would suggest you inspect them first. Unless everything is free to move and lubricated adjusting will be fruitless.
