If the starter isn't up to par,battery cables too small,battery of smaller capacity,battery low on charge, or poor connections its not uncommon for a fresh rebuilt engine to not turn over with 6 volts.Years ago some of the mechanics made them so tight it was necessary to push the car to get it started.This was before 12 volts.
After runnig at a medium speed for a while you should notice a marked improvement - except it will still turn over hard when hot....After about 1000 miles it will be back to normal.
If you do let it sit and run keep engine speed well above idle so as to throw the oil up on the cylinder walls.
