Does anyone carry clips or original style steel strip to attach the stainless mouldings that are on the crowns of the quarter panels? I'm looking for them for a 4 door so the attaching screws for the front part aren't necessary. Also what part number if they are supplied ? Too, can I make a crown moulding from a Styleline fit a Fleetline with a little tweeking, flexing? I have a used one for the passenger side that is correct, but have only found a driver's side that was decent enough for a driver off of a Styleline. I have found a correct one for the driver's side, unfortunately it has been scorched with a torch when the fuel door area was cut from the donor vehicle. I don't believe it would polish out. I may have to use it if I can't make the one from the Styeline work. If so, back to the junkyard.
