#438151 02/09/20 06:25 PM
honk1e Offline OP
I am trying to identify if the 3 speed trans in my 1937 1/2 t p.u. is a '37 or if it was replaced. I ordered a new tower repair kit from Carter (bushing and spring) but does not look like my tower. The spring is bigger than my original and will not fit. I tried to find what year my trans. was, but found no info. The # on the casing is 590874. Thanks for any info. you can give me.
Honk1e
honk1e #438153 02/09/20 07:24 PM
The case is for a 1937-1939 three speed truck.
honk1e #438170 02/10/20 06:43 AM
honkie,
Gene is correct. I checked the case number in my 1929-1950 Chevrolet Parts Book and it lists in Group 4.103 Case, Transmission 1937-1939 ALL COMM 590874 (cast) Part No. 590875.
Perhaps you received the wrong parts. Seems so. dance
Best,
honk1e Offline OP
The Carter book says it fits '37 to '47 3 speed floor shift. I will call them and ask questions. Thanks for the responses. Is it possible that the trans tower is from something else? Is there a # on the tower? I will check tomorrow but I don't remember seeing one.
Thanks again
honk1e
honk1e #438199 02/10/20 11:23 PM
The parts book says the spring fits 1937-1947 3 speeds.
