Posts: 1,072 |
are the front motor mounts for a 50 car and 51 truck the same set up might have a guy looking at my 56 235 that i was going to put in my 50 coupe i changed the front mounting plate and made the cam hole bigger, and installed a couple of studs for the timing gear cover for easier cam removal and also so i wouldnt have to drill new mounting holes back to question are both front end set ups the same thanks
