I have a 35 std which has a similar engine. There was a metal sleeve between the carb and the intake manifold. It sometimes is not installed and I did not miss it. The car developed an erratic miss at various speeds and I changed everything I could think of. After years I removed the head for some reason and found pieces of that ring at the end of #6 cylinder in the intake manifold where it had been acting like a shutter when it vibrated into the right (or wrong) position and caused the miss. The piece is preserved to show how hard it is to solve some misfires
