#43756 07/18/05 10:53 AM
What should the clearance be between the oil dipper and trough on a 194 CI? Where can I find a tool to measure this clearance?
#43757 07/18/05 10:16 PM
The way I have done this (on a 216) is to fill the troughs with cup grease level to the top then ease the pan back on and turn the engine over a couple of times, in the running direction, by hand then pull the pan and see how deep the groove is that was cut by the dippers, it will give you a good picture of what is going on.
The amount of the groove should be in the shop manual. It isn't very deep in a 216
#43758 07/19/05 02:01 AM
That's a good tip MrMack.
Bill Masters
#43759 07/19/05 04:40 AM
Sounds simple, yet effective!!
#43760 07/19/05 09:04 AM
I like the grease idea, some where I read a post about this and the suggestion was to use modeling clay, can you imagine the mess! talk talk
#43761 07/19/05 06:08 PM
Thank you MrMack. I will give it a try.
#43762 07/19/05 06:23 PM
Also check to see if the oil lines on the side of the block -left side- line up with the troughs below.
