as many know i have been working on the engine and having it rebuilt, in regards to the transmission... would like to give it a GOOD once over before i get the engine back and ready to go in.
I see that The Filling Station sells an overhaul kit with new shafts (counter & Reverse Idler) and related bushings, as well as a bearing retaining, new shaft bearings. the overhaul kit and bearing retainer are produce by C&P Automotive (Billy Possum)
[Linked Image from billypossum.com]
1923-1931 Transmission Rebuild Kit. Due to bushing and shaft wear the gears in the transmission are allowed to move away from each other, increasing the load on the gears and causing excessive noise. This kit contains a hardened and ground countershaft and reverse idler shaft, countershaft bushings, reverse idler bushings and the main drive gear bushing. The expansion plug and cotter pins required for assembly are also included. All parts are identical to the originals but with sintered bronze bushings for long life. p/n 328671, 328662, 590236, 590199, 590412, 117923 and related cotter pins
1925-1931 Transmission Main Drive Bearing Retainer (with elastomer seal). This aluminum part remedies the problem of warp in the original pot-metal retainer and the elastomer seal prevents grease from leaking out of the front of the transmission. p/n 590409A
how can i tell if bushings and shafts are in need or replacement ?? gears look to be in good shape, no chips or breaks on any of the teeth.
well decided to get started on the transmission...
here is the Transmission Rebuild Kit & New Bearing Retainer I got from The Filling Station (Made by C&P Automotive) also got the new bearings while i was at it. very nice kit, has 2 new shafts, pins, cap & required bushings.
Following the instruction in the 1929 Chevrolet Repair Manual, took my time and tore down the transmission.
Here is the initial ROUGH Tear down to bare housing...
housing with internal components
housing looking inside
front view
rear view
passenger side (fill port)
bottom
drivers side
20200215_101753.jpg 20200215_101758.jpg 20200215_101838.jpg 20200215_101844.jpg 20200215_101849.jpg 20200215_101912.jpg 20200215_101922.jpg
now here are the internals broken down...
shafts, gears, keys, and pins oh my
20200215_101931.jpg 20200215_101937.jpg 20200215_101944.jpg 20200215_103333.jpg 20200215_103337.jpg
now to clean everything down and then prep for rebuild
going to soak and scrub the gears down then inspect them for defect, chips, cracks, etc...
see what it all looks like after some cleaning :)
well got all the gears cleaned up as well as the housing...
20200216_141221.jpg 20200216_141233.jpg 20200216_141237.jpg 20200216_141242.jpg 20200216_141246.jpg 20200216_141253.jpg 20200216_141257.jpg 20200216_141300.jpg 20200216_141310.jpg 20200216_141313.jpg
shaft
20200216_141325.jpg 20200216_141333.jpg 20200216_141336.jpg 20200216_141341.jpg 20200216_141345.jpg 20200216_141348.jpg 20200216_141353.jpg
Cluster
20200216_141400.jpg 20200216_141406.jpg 20200216_141412.jpg 20200216_141416.jpg 20200216_141419.jpg 20200216_141423.jpg 20200216_141428.jpg 20200216_141431.jpg
Splined Shaft
20200216_141616.jpg 20200216_141633.jpg 20200216_141639.jpg 20200216_141645.jpg 20200216_141649.jpg 20200216_141653.jpg
Cluster 2
20200216_141439.jpg 20200216_141446.jpg 20200216_141451.jpg 20200216_141502.jpg 20200216_141505.jpg
cont...
20200216_141510.jpg 20200216_141519.jpg 20200216_141526.jpg 20200216_141535.jpg 20200216_141538.jpg 20200216_141552.jpg 20200216_141607.jpg
They look good to me, especially the main drive which I had to replace on mine.
Thanks Bearsfan, I’m going to be getting into this shortly. Big help.
hope to start putting it together soon
question for anyone that has rebuilt their Chevrolet transmission using the kit & parts i noted above.
did you remove one side (facing inwards) of the bearing shield or leave it in ?? any issues, concerns, and/or recommendations ??
The rear bearing should not have any shields so oil can enter the U-joint. I would remove the inwards shield on the front bearing.
devil Agrin
I followed The TFS instructions for the Main Drive Bearing and removed the inner seal. As I remember it was not difficult.
well got around to re assembling my transmission. been trying to get everything in order for our annual swap meet so been busy !!
laid out everything on my bench then started to reassemble. used my Harbor Freight 20 Ton Press to press on the bushings. i used a lights coat of oil to ease to process. this was really easy to do, as long as you ensure everything is straight and in line.
did this for all the bushings on the gears/shaft. took my time and made sure it war correct.
once all the bushings were installed i did test fit each shaft to ensure that they went in smoothly and freely and spun with easily with no slop or play.
also use a technique previously discussed to put in some grooves in the bushings for oil.
next up was the bearings... this was a little more tedious, as wanted to make sure i supported the races on the bearings that i was pushing/pressing against. do not want to scar or flat the balls.
the black gook on the shaft was grease, used grease and oil coat to ease installation...
first to go in was the counter shaft cluster and shaft... then the reverse idler cluster and shaft. used the new shafts in the C&P Automotive rebuild kit.
this was a test fit, still need to line up holes and drive in shafts then pin them in.
20200301_163122.jpg 20200301_163128.jpg 20200301_163143.jpg 20200301_163049.jpg
next up was the main drive gear and shaft,
then the spline shaft assembly and gears. used my press again to press in the bearings into the housing and seat everything.
then i made sure that all the gears moved freely and that i could work the gears into all ratios with out an issue
i have not pinned the shafts in yet, just in case.
next up will have to pin the shafts to secure them in place, and then start on the u-joint housing and assembly !!
20200301_183251.jpg 20200301_183256.jpg 20200301_183301.jpg 20200301_183307.jpg 20200301_183310.jpg 20200301_183315.jpg
Nice job! That does look like a nice discrete project that all fits on a single workbench.
thanks, yeah not many parts, and nice to lay it all out :)
drove in the shafts lined up the holes, put in the pins, and pulled them over. shafts are now in there to stay !!
20200302_193340.jpg 20200302_193347.jpg 20200302_193353.jpg 20200302_193825.jpg 20200302_193829.jpg
