Posts: 1,072 |
well finally got all parts together redo 53 with bushing type cluster question is how do i line up the the 4-lugged synchro cones and how do i know i have the one in the rear at the right spot of course the cones have 2 lugs the same size and 2 smaller ones is there only one way or 2 ways that they will go on when you slide the main shaft thru, the needle bearings i think got right according to my book which only shows 50 trans with just one set of 14 so i guess proper order is 14 needles then a spacern then another spacer then 24 but one diagram shows an extra spacer that was not in trans when i took apart anybody tell me the right way and the other is the main shaft tough to get trhu the rear bearing i dont want to pound on it too much seeing i dont have the proper puller to pull it thru any help or pics would get me on the right track thanks
