Posts: 216 |
Do you have to put any sealer around the edges of freeze plugs before you press them in?
1939 Chevy 1 1/2 ton dually rear wheel pickup 1940 Chevy 1 1/2 ton single rear wheel pickup 1946 Chevy 2 ton cab and chassis 1977 Chevy 3/4 ton camper special 4x4 Obsessed 16yr old Chevy truck nut
It is a good idea but normally not necessary. With our older engines any corrosion or irregularity in the seat area for the "Welch plug" (yes they are really Welch plugs and NOT freeze plugs) could result in a leak. Best to add sealer to be sure that everything is A-OK.
Posts: 216 |
Ok thanks. I just punded them in and used a bead of high temp sealer.
Posts: 279 |
Bob,
I would recommend a sealant such as Permatex #2. I would not use a silicone sealant (which I think you are using based on your comment of "bead".)
The silicone type will not seal well in this application.
Oliver J. Giorgi Technical Advisor 1958 Passenger Car
Posts: 216 |
I did not use a silicone sealer, I just meant that I coated the edge of the plug.
The universal sealer: "SNOT". Just dip the "welch" plugs in old faithful and install. If you coat the steel plugs in the magic formula it will also delay them from rusting.
Posts: 3,542 |
