Posts: 27 Likes: 4
Posts: 27 Likes: 4 |
I've got a '36 panel. It doesn't have the original rims on it at this time but I do have them. Looking at new tires and tubes. Do the artillery wheels need flaps/liners?
Posts: 435 Likes: 2
Posts: 435 Likes: 2 |
1936 GMC T-14 low cab. TA for 1935-37 GMC, Director of the Gulf Coast Region
Posts: 1,478 |
I have added these to help with tube wear. I have some rust pits starting to form along the rivets due to water condensation (before I repainted the inside of the rim). These pit places will cause the tube to rub a hole in it. The (flaps) liners stop that. Make sure you get the correct size. Loose liners will do no good.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
The liners need to be a tight fit to the rim before the tire and tube are fitted though are really needed for 2 piece rims (truck style). Tony
Posts: 27 Likes: 4
Posts: 109 |
Yes because of the rivets in side of hub of the rim.
