cprop Offline OP
I would like to install a 283 engine in my 49 sedan. Any information would be greately appreciated.
hurst at one time sold motor/frame mounts to install a sbc in the 49 to 54 chassis. you'll have to butcher the two vertical strips that run one each side of the 216 in order to clear the sbc'c heads. if you're gonna install the sbc, ya might as well go with a muncie or t-10 4 speed and an open drive rear end. good luck, mike
