#436192 12/24/19 02:38 PM
Does anyone know the correct part number for a 32 steering box? I am looking at a box with the numbers 260367 with a 1 above those numbers. I tried to look at the numbers on mine and they seem to match except I can't make out the 2 on my box and I have an 11 under the serial numbers. I am guessing they are the same, but like a bit more verification.
Thanks and Merry Christmas and Happy Holidays to all
1932 5 Window Confederate Coupe Best of Era 6 cylinder 2016
1968 Corvette Roadster 383 CI-425 HP
1938 Business Coupe "personalized"
The part number is 260362 and uses the 260367 housing casting but that casting is also used for several years. I suggest you contact the 32 advisor listed in the G&D for info on how to correctly identify the box you have.
