while waiting on my engine to get done, i decided to send out my 2 spare distributors to get them built into 1 good one.
send them out to JYDog to get a good one :)
got my Distributor back on Thursday !! man does it look sharp. top notch quality work. tested on the Distributor machine and good to go !!
cant wait to install it on my rebuild engine when i get it back, sure it will work just fine
20191006_075042.jpg 20191211_193944.jpg 20191211_193955.jpg 20191211_193958.jpg 20191211_194001.jpg 20191211_194042.jpg 20191211_194106.jpg
It looks great but I would be a little leery about the drive gear as it appears to have some wear and pitting. I may have one that is better-would have to check as I do have a couple of "parts distributors'.
Who is JYDog?
31 Chevy Roadster
64 Corvette
76 Corvette
77 Grand Prix
JYD is Junk Yard Dog on this forum.
I would not be concerned with the minor surface pitting on the gears. It might wear some in the next 10,000 miles. There is lots of oil splashing around where this mates to the gear on the cam.
OK thanks I didn't make that connection. Senior moment.
31 Chevy Roadster
64 Corvette
76 Corvette
77 Grand Prix
Forgive me in advance for restarting an old thread-
@BearsFan315, I’m in the process of rebuilding the original 633g on my Dad’s 1930 AD, and I’m trying to figure out where to purchase the distributor insulator that mounts to the large hole on the distributor and connects the external condenser to the ignition contact point set. Couldn’t find it on either The Filling Station or Hagans.
Looking online I can only seem to find them for tractors, and it looks like the interior shielding piece protrudes waaaay to far past the housing wall.
Any help would be greatly appreciated!
Detour
If you are looking for the barrel shaped insulator that goes into the hole in the side of the distributor, I make them. They are a critical part in the rebuilding and installation of the electrolock ignition switch assembly.
as Chipper Noted he makes that insulator.
he also does the rebuilding when he has his machine running, Junkyard Dog rebuilds them as well, as he is the one that rebuilt mine since his machine is running, and he could test/validate it. did a super job as you can see. i am still waiting for my engine to get back from the engine shop so i can put it all back together !!
These guys are listed in the Generator & Distributor Magazine as Tech Advisors, may of us call them specialists :) especially on these older Chevrolets.
