Posts: 201 |
My horns works good on 12v and not at all on 6v???? What's up?? Voltage shows 6.45v at the terminal block.
Johnny Reb
They just need adjusting.
Posts: 201 |
TY......I will check...Do I have to take the halves apart..?? I can not see the adj. screw???
Johnny Reb
Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
If they are 6 volt horns, 12 volts will burn them up.
Jon T.
Posts: 201 |
TY....I just touched them with the 12v ...
Johnny Reb
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Just take the cover off and you will see the adusting screw. Hook it up to 6 volts and adjust. Good luck, Charlie
Posts: 201 Likes: 2
Posts: 201 Likes: 2 |
If they are 6 volt horns, 12 volts will burn them up. I was under the impression that 12 volts wouldn't damage them as you are only using them for a brief moment. I understand one could burn them up internally if one "laid on the horn" . Also you can run them in series after isolating one from ground.
Posts: 9 |
S'cuse me for buttin in - - how does one tell a 6 volt horn from a 12 volt horn? Are they marked 6 or 12 volt?
A 6 volt will ot be marked because all horns were 6 volt years ago....12 volt is usually marked.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
If they are 6 volt horns, 12 volts will burn them up. Not true if they are used normally. As a child, when my parents bought a different car (12v), dad would immediately go to the salvage yard and bring home 6v horns because the stock 12v horns weren't loud enough. Never did any of the horns burn up. Granted, if you lay on the horns for an extended period of time they will be damaged but normal usage will not harm them.
Posts: 201 |
Johnny Reb
