Camile Offline OP
I've been searching high and low for a replacement gas tank for my '38 Chevy Truck. I haven't had much luck. I've found many for a car and many on every year but my '38. Does anyone have any advice on where to look?
As a last resort you might try a fabrication shop and have
them fabricate a tank ? hood
p.k.
1956 BEL AIR 2 DOOR HARDTOP
Camile Offline OP
That looks like what I will have to do. I have a call into a local aluminum welding shop that I used to work for. If I can't come across one I will go that route.
There are outfits that specialize in restoring fuel tanks. Your original would have to be very bad to not be restorable. It's not cheap but likely much less than paying to have one fabricated AND you know it'll fit.
For some reason Chevy in its infinite wisdom decided that the '38 truck tank would be unique for that year. I agree with Tiny that I would research restoration before fabrication.
While I agree that a fabricated tank will probably work, I doubt if the shop can make it fit the space as well as an original and have the same capacity and mountings. I expect that it will also be made from thicker material to prevent flexing and oil canning. They will probably not be able to stamp the strengthening ribs into it.
Check it out !
http://www.gas-tank.com hood
p.k.
Camile Offline OP
Exactly correct about the '38 tank. However, I will assist in the construction of the tank so it will have a chance to be closer to fit.
Camile Offline OP
Check it out !
Thanks!! I will definitely check them out before I start constructing my own.
Here's some info about building your own tank: Building your own gas tank article
Camile Offline OP
Great info!! Thanks Dean
Camile, it would be worth your time to check with JimCarter truck parts in Mo. I've been there many times and he has good used parts in the basement and out in the yard. A phone call may ease the search.
1937 Chevy 1/2 ton Pickup
1950 Chevy Styleline Deluxe Coupe
1953 Chevy 1/2 ton Panel Delivery
I'd rather walk and carry a Chevy hubcap than ride in a Ferd.
Camile Offline OP
Will do. Don't know why but I didn't check with them yet. Honestly, I was thrown off when the Filling Station didn't have one for my truck.
Things can get very frustrating sometimes ! hood
p.k.
