#435230 12/03/19 05:10 PM
What lube should I put in the grease cup of my newly rebuilt 1928 water pump? Thank You.
1928 2dr Coach
1930 4dr Sedan
1930 3 window Coupe
1937 4dr Master Deluxe
1941 Special Deluxe
1946 Willys
1946 cj2a
1953 2dr 210
A water resistant lubricant. Several manufacturer "water pump" lube. Also can use marine grease but make sure it is the high viscosity lube.
Chipper #435386 12/06/19 06:03 PM
the local napa store has some good stuff for the grease cup. Thank You for the reply and help.
1928 2dr Coach
1930 4dr Sedan
1930 3 window Coupe
1941 Special Deluxe
1946 Willys
1946 cj2a
1953 2dr 210
