Mike, I did the "Search" but didn't find anything relating.
Questions:
a. What is the best brand of safety switch to use for interrupting the flow of juice from the battery"
b. Where is the best place to mount it?
c. Is this a points deduction item?
d. If you have a fire do you try to put out the flames first or try to ignore the fire and pull the hood latch, open the hood, go to the trunk and search for a suitable wrench for the battery cable, ruth back to the battery, take a cable loose and then attend the fire which by is out of control. Whilst roasting the marshmallows call 911 and ask the dispatcher they want to attend your little party.
I have a quick release on the negative terminal of the battery now. It works so well that I carry a coat hanger and package of marshmallows with me at all times. Also, I leave the positive cable loose enough that I can eliminate the trip to the trunk and search for a suitable tool.
Fire extinguisher? If you're fast enough you may be able to save it but the marshmallows may come first.
i have had two under the dash fires on my 41s. Panic time!
Any help would be appreciated. Maybe a check list of what to do if a fire occurs anywhere on the car? Be sure to include all the stuff for making smors.
Best,
Charlie
