Posts: 88 |
Need help in how to remove brass plug from Carter carburetor. Cannot unscrew without damaging plug.
Jim G
Posts: 1,294 |
Concave grind a large screwdriver to fit snug. Should come right out.
Having the screwdriver blade exactly fit the screw slot is necessary. Also have a sharp bladed screwdriver. Those tapered, rounded ones destroy screw slots. I have found it necessary to twist the screwdriver counter-clockwise and then clockwise numerous times before releases and backs out.
Posts: 88 |
After grinding a concave end on a screwdriver I was able to remove one screw, But since the screwdriver was tapered it still damaged the slots on the others. I wished I had seen the note on using the sharp bladed screwdriver earlier. However I was able to remove the other screws by drilling a shallow hole and using a screw extractor. The screws are still usable can can be tightened with the extractor or screwdriver. Thanks for the help. In the meantime I am waiting for a Carb repair kit to arrive..
Jim G
Posts: 424 Likes: 6
Posts: 424 Likes: 6 |
If you are working with brass plugs in cast iron:
First get ALL of the springs and zinc alloy away from the casting. Then place the cast iron casting in a toaster oven (electric) and heat as hot as you can Then remove the casting, and spot heat the area AROUND the plug until cherry-red. ALLOW TO COOL NATURALLY - DO NOT QUENCH IN WATER! Generally, at this point the plugs may be removed with zero damage, often with your thumb-nail.
This also works for steel screws; just make certain you have previously removed ALL springs and zinc alloy parts.
Jon.
