Posts: 23 |
Hello, I have the following question. Which modern lubricant oil brand and type are you using for the following: - Chassis - Gear box - Engine - And for the Hydro electric pump for those who have a convertible the hydraulic top fluid. I have all the old references in the chevrolet manual but I am curious to know if there is one special modern brand or type that is recommanded for those cars today. Thank you, Best regards, JC
Posts: 535 |
Based on successfully showing, touring my 1950 convertible for 27 years and about 10,000 miles: Top motor: DOT 3 brake fluid Chassis: regularly available chassis grease Motor Oil: name brand 10W-30 Manual Transmission and Differential: SAE 80W-90 Gear Oil
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
granted that GM used DOT 3 brake fluid in their electric over hydraulic systems in the 50's, I use ATF when I rebuild the power top assemblies on C-1 corvettes and our 50 chevy convertible. if one has ever disassembled the pumps and solenoid assemblies on these old GM systems, one will find a considerable amount of gelled material therein. most convert top experts suggest using ATF. of course, before using ATF, the entire system needs flushed of old DOT 3. mike mccagh
Posts: 23 |
Thank you for your answers. We disassembled the Dura pump and it is rather clean inside, but I want to replace the gaskets as they seem to be a little worn out... I want to gather the more information I can so that I can use the right fluid as I don't want to make any mistake. I porbably did not use the right term for the chassis. I meant the whole transmission system and differential. But I think you understood me. thank you JC
