h
how can I tell if this 51 car speedometer is any good or good only for parts?
thank you
jerry whitfield
Winston salem NC
Cordless drill?
I put a shortened pencil in the drill and drive the speedometer with the eraser end. If you can get a constant speed going, then you can observe the miles traveled over a few minutes, figure out the miles per hour represented by that speed and see if the pointer matches that.
The drill idea sounds like a good one. Once you determine if it's kerplatz or not, check your speed against those digital "Your Speed Is.." signs on the roads for accuracy. Mine reads 3 mph high so it's my anti-ticket device now.
Good luck.
Rick
