Hi all, I am a newby and an Australian. I have recently acquired a 1948 Fleetmaster. I need to replace the front seal. The pulley has a crank handle socket on the front of it so no bolts etc.
Are they just pressed on or is there a secret to getting them off?
Appreciate any advice you can give
Tony S
Become a Member!
It is pressed on and a puller is necessary to remove. Installed with a big hammer and do not pount on the outer area....I use a large pipe and keep the pressure of pounding on the area around crank handle socket.
This is a good topic for doing a SEARCH of our old posts. Use the search terms +harmonic +balancer and the Display Name Mike Buller Or Chev Nut. Attached are some pictures which update the process mentioned in the posts.
Good luck, Mike
I use an impact gun on the puller. The shock of the gun tends to help the pulley to move out.
