1. Yes as already posted driver side inside visor was standard the passenger side is an accessory.
2. The dash clock was electric. A rear view mirror clock was windup.
3. No glove box on Chevrolets until a couple of years later. Other makes had them in 1932.
4. The rear seat bottom is removable. There is limited space under it. Many with side mounted front fender (or two) use a trunk rack on the back with separate trunk on top of it. There is also an accessory solid mounted trunk.
Thanks!
If anyone has a picture of their interior, showing the sun visors, that would be helpful. -- Jay
Steve, I can't imagine with the visor down you could see safely out that narrow windshield. I never looked into installing one because of that concern. But you have more road experience than I do. And your'e shorter.
Charlie I don't think I have ever needed to put the visor down more than a couple of times. It does need to be there to complete the original interior though.
You may be able to have the visor made by an upholstery shop. I have an original visor only that you can have . It's complete but well worn and could be used to replicate or use as is. Send me a PM with your address and I'll drop it in the mail.
Oh, my goodness -- that would be fantastic! Thank you so much!
The seller included a partial bolt of the original material used in the interior, so we should be able to make it match perfectly!
I owe you one. I will try to send you a PM here in a minute. -- Jay
I found both sides hardware Left side chromed and not chromed . Right side chromed plus visor's original and new If I can get your phone number I'll send pictures
Sweet! As long as they are functional, I can always have them re-chromed!
