I have been using AC LM-46 lawnmower plugs in the Pontiac. They are one range hotter than the AC-45 that seem to be listed in the place of K-7 after 1936. There has been no indication that they are too hot. I am quite happy with them. K-9 is hotter than K-7 IIRC, so you might be able to get away with that as well.
LM-46 are non-resistor, have a short insulator, and an unplated base, much like the old K-series plugs. It looks pretty good from 10 feet, and is the best looking thing I could come up with that is readily available to just buy and use up.
