Posts: 1,072 |
what would be the numbers stamped on the trans be for a 54 manual trans are they the same as the engine and vin numbers
The stamped trans. numbers have nothing to do with serial numbers, etc. The 1954 3 speed car numbers Will begin with a M or S followed by a number for the month and another number for the day of the month. A year code is not used so a 1953 could have the same numbers ans letters.
Posts: 1,072 |
thanks gene you had already given me the numbers i needed M-8-18 AND S-8-26 i just didnt know if they had stamped or cast a year on the trans any where thanks again andy
Posts: 1,072 |
where are the casting marks on a 53-54 manual trans have a guy looking at transmission he cant find the numbers am looking for are they on the top like a 50 or on the shifter housing or
Posts: 1,072 |
he found some casting marks neither what looking for one was B253 the other was L120
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
The year is not given there and the same numbers and letters were used for more than one year.
Posts: 1,072 |
lesson well learned drove 3 hours to see a 54 trans freshly pulled from a 54 and guess what it was a 49 with the tail off of a 53-54 not what i wanted guy swore up and down it was a 54 here are the numbers that were on the trans let me know what you guys think c or g b 184690 - 591747 GM49 there is no way in my mind after speaking with gene that this is a 54 trans what a terrible day but thats the way it goes so the search continues
The case casing number of 591747 was used from 1949-1954. Just that they did not drill and thread the mounting holes in the case on the 1952-1954 models because the mount was bolted to the rear extension.
Posts: 1,072 |
i think i found the trans am looking for but not sure the guy said it came out of a 53 -216 the numbers on it are GM29 and then the small casting has 12-18 is the better trans to use for rebuild of my 50
Posts: 114 |
Hi Gene,
Owning a '52 Fleetline myself, I've heard plenty about this jumping-out-of-high-gear problem. Fortunately, I haven't had to deal with this on my cars, which seems to do fine no matter if I'm on the throttle, just cruising on the flats, or decelerating. The two times I did see this happen with a fellow VCCA member's car, we were on a flat road, and it happened when he backed off the throttle just enough to be coasting in gear. I know that the changes to the '53-'54 passenger 3-speed was partly to help correct this. What I'm curious about is have you or anyone you know ever run across this particular problem with '55 and later passenger cars?
Scott Andrews Dacula, GA #J25833
I can not recall of a 1955 or up jumping out of high gear.........or a 1953 or 1954.
