#431372 09/19/19 07:12 PM
I own a 51 bel air, got a 54 235 under the hood. I have a rear main seal that has gone out. From everything I’ve read it seems the rope seal is the best bet. Also from what I’ve read it seems you have to take out the motor and remove the bottom to Adequately replace it. Is there any other gasket or seals that should be changed while doing this as a preventative? Also has a offenhauser valve cover. I used a valve cover gasket for a 54 and it doesn’t seem to seal tight enough. After doing a little reading it seems like a 37-53 gasket is best?
Become a Member!
I would consider purchasing a complete gasket kit which would allow you to replace all the engine gaskets. Taking the head off will tell you a lot about the corrosion in the cooling system, which you could flush out as well as the water jacket of the block. You could basically go through the engine looking closely at its over all condition.
Chevs of the 40s overhaul gasket kit
Good luck, Mike
I have been successful replacing the rear main on both my 216s, in the vehicle. I have found that they won't seal unless the main bearings are adjusted to their minimum clearances, something that is difficult to do in a motor without shims. I have found that the best rope seal is made by Best Gasket.
old216 #431404 09/20/19 03:08 PM
The neoprene seals do the best job but you must (a) polish the sealing area on the crank and (b) shim the seals so that a constant contact is maintained. As mentioned above if the main bearing clearances are too large, you'll have trouble with either seal type. If the sealing area on your crank is rough and pitted, consider using a "Speedi-Sleeve" on it. Good luck. This for the 235 is a common problem.
Jon_G #431433 09/21/19 05:11 PM
Woo! Enlighten me on the Speedy-Sleeves for the crank. How are they installed?
devil Agrin
To my knowledge a speedie sleeve cannot be installed to the rear of a crankshaft, the flywheel flange is in the way.
At a certain point in time, I don't know which year, the block and cap were machined to accept the neoprene seal. I think it was sometime after 1954.
old216 #431462 09/22/19 12:37 PM
The 1955 blocks were the first to have the deeper seal area and it was not to accmodate the neoprene seal The rope seal was used in production until the end of the 235 blocks,.
The neoprene seal for replacement came along in the late 1960's if I remember correctly and was designed to be used for 1955 and up. It was first used in production in 1959 for 8 cylinder engines.
The neoprene seal can be used in 1940-1954 blocks by adding something behind the seal to bring the lip out far enough to contact the crankshaft. This requires shortening the sea by cutting a little off of the ends. I used nylon wire ties in my 1950 to insert beind the seals to accomplish this. After several years still no leaks.
