I found these brackets in a coffee can with other odds and ends that my Dad had saved from the '31 Sedan. Does anyone recognize what these are and where they are used on the car? I disassembled the car and don't remember anywhere that they could be used. They might not even belong to the '31, but thought I would ask.
--------------------------------------------------------- Thanks much, Ralph "Roll Tide"
These two pieces go on the inside of the back fenders. One on each fender. I can't remember exactly the location but they are on the inside near the back. If you hold then at each bolt hole you will probably see where they fit. I don't have my '31 or I would go look and tell you exactly. Sorry
I drove over to where the car is and looked. That piece is held on by a hex head screw. Starting at the bottom of the rear fender and the gas tank cover you go up three stove bolts, then a hex head and is held on by a hex Head Bolt fifth position. When you hold it there you will see the correct orientation. Hope this helps
