#430933 09/10/19 11:59 AM
How thin is too thin to have drums turned? And how do you measure the thickness?
Normally the wear limit for a brake drum is established as a maximum inside diameter for the braking surface. Most brake drums from the 50's and newer have that actually cast into the rim of the drum.
I have never looked on any older drums. Probably should!
I'll look for that info tonight
The limit of .060" over the standard ID of the drum was a pretty common figure in practice. I am talking about ordinary drums for a sedan.
I have two drums off a 52 if anyone needs them.
I haven't found any markings as to the diameter of the ID on the set I have ,but I suspect they may be too far gone judging by the outer lip left from the shoes wearing in the drum. Not to worry though the set is off of a rear end I just discarded. I thought about keeping them for spares. Most likely I would just replace the entire rear end with one from '51 or later for the Bendix brakes anyway.
