There seems to be more oil than there should be coming from the engine at the bottom of each intake and exhaust rods??????
What do I need to do to lessen it?????
Johnny Reb
Not trying to be cute but I sure would like to know what intake or exhaust rods are?
Setting on top of the valve lifters at the bottom of the motor is a push rod for the intake and a push rod for the exhaust valves, the valves are in the top of the engine. As the lifter lifts it pushes the intake or exhaust rod up to open or close the valves. The valve spring pushes the rod back down to cycle again. sorry, I thought you knew??????The valves open and close at different time to allow gas in and exhaust out.
Or were you just being???cute????
Johnny Reb
That's the nature of the beast when the lifter bores get worn. Mine does the same thing. Use straight 30 weight oil; nothing heavier because it's a splash oil system. It might slow it down but won't eliminate it. I've been thinking of a fix but haven't got around to see if it would work. Just carry a spare quart of oil with you.
Steve
TY Sir....I was wondering if some heavy felt washers would help????
Johnny Reb
At one time you could get oversized lifters. Had those in the 28 Touring I used to have. Don't know if such a part is still available. Enough demand for oversize lifters might get someone to produce them. Don't know of any other solution to the oil bypass problem.
devil Agrin
A friend of mine had a similar problem with leaky lifters on his '27 tourer engine,and he slowed the mess down by making 2 sheet steel "dams" higher than the lifters,screwed to the block(after he pulled the engine out for an overhaul)with sealant between the sheet metal and the block.
CJP'S 29
TY..................
Johnny Reb
That is an innovation I had not considered????
Johnny Reb
Oh pushrods! Correct terminology helps others help you.
Now you are being cute....must be a Canadian thing??
Johnny Reb
