#430015 08/21/19 11:46 PM
dgstarr Offline OP
A fellow VCA member is trying to locate mohair material for his 35 Chevy interior.
Does anyone know of a current sourse?
Mohair material is no longer produced. Your local upholstery shop has books. My local shop matched a fabric that looks extremely close to the original. They were able to do stitching and fuffing that is exactly like the original. There will be a lot of "hand stitching" over the rear of the seat. That will take a lot of time and proves to be expensive. Good luck on your project.
When did this happen? Is it related to the Lebaron-Bonney drama somehow?
Just checked on Google and there are all kinds of places that still list mohair material.
THH Offline
I agree. I will be dealing with the same problem with my 36 shortly. Just ordered some samples from this place.
https://www.decoratorsbest.com/search?view=results&q=mohair#
Super expensive but I have always believed you only get what you pay for. We'll see if it comes close to the original.
Mohair has been super-expensive for a really long time. When I was working in an upholstery and trim shop in the early 80s it was around $100-$130/yard. Vinyl was about $12-16/yard. I gather it must have been much more affordable in the 30s as nearly every make used it on some cars,
I remember it being on very early 1950s cars. It probably was cheap when made by the square miles per year back then. Nobody except restorers, uses it now.
Vinyl was probably expensive in the 1930s.
Doug
