Posts: 5 |
Hello all Three years ago I bought in californien a Chevy truck from 1922, so it is in the papers.! Some days ago I bought ignitions parts in Garys store, and after seeing my truck Gary is saying, that my truck is a 1927.. Here some number,which I found,please help to identife Engine block right side 2000711 Number on the clutch housing.? Is 348871 Engine block left side 0? 12 last 7? Under the dash a plate 6R1293 Thanks for help Lukas Poland
What a bunch of numbers that don't really identify anything. Perhaps if you copied the numbers on the HEAD that would help. About the only number that checks out is the 6R1293. That would indicate a truck from about Sep/Oct 1925 built in Oakland. The other numbers just don't add up. It would appear you have a 1925 truck with a changed engine that is probably a 1927 engine. To get better answers, get the information from the head and go back and see if you can make a better reading of (0? 12 last 7?). That number smells like a 1927 number. Give us another shot.
Posts: 5 |
Hello Thanks for your answer, This number is on the head 648540 That helps.?
We still need more numbers and letters from the head. There should be a date on the head. I think I have locked in on a 1924 block now. Is your clutch a cone clutch or a flat disc? With the correct numbers we will identify your head.
Posts: 148 |
Hi, the motor is a '27 the rest your going to need photos
Brian
Posts: 812 Likes: 13
Posts: 812 Likes: 13 |
ID # 6R1293 translates into 6 = assembled in Oakland, R = Early 1926 One Ton with 124" Wheel Base, (X = late 1926 One Ton 124" WB), (M = late 1925 with 120" WB), 1293 = serial number. It is quite possible that parts from many years were assembled in the truck that was sold to you. If it has a parking brake lever near the gear shift lever, it is 1922 or newer. If parking brake is center pedal with ratchet, it's 1921 or older. A photo will tell all. Good luck, Lou
Posts: 5 |
Hello thanks a lot for the answer,sorry for the delay.. Yes my parking brake lever is next to the gear lever,so after 1922, defintly not like in the papers... Here some fotos, I hope it will work...
