#429881 08/19/19 06:04 PM
Bama31 Offline OP
Need help interpreting the stenciled markings on my '31 Sedan. The date 5/28/31 is readily visible which is about the time the vehicle was built. But not sure what the AOS means. And there are some other illegible markings after the date. Any help would be greatly appreciated. Thanks.
Thanks much,
Ralph
"Roll Tide"
Bama31 #429882 08/19/19 06:49 PM
"AOS" stands for AO Smith Corporation (Arthur Oliver Smith) and they made automobile frames for Peerless, Ford, General Motors and etc., along with many other products as well. The company is still in business today manufacturing hot water heaters.
Bama31 #429883 08/19/19 06:52 PM
You will probably not find anyone who knows what the markings after the build date are.
Jon T.
Bama31 #429884 08/19/19 06:58 PM
Bama31 Offline OP
Thanks. Good to know. Thought it would be right to duplicate the markings when I get to that point in the rebuild.
Thanks much,
Ralph
"Roll Tide"
Bama31 #429893 08/19/19 08:20 PM
I duplicated the original frame stencil on my car when I restored the frame.
a little discussion with links to history and info on AO Smith in regards to frames
You can go to Google and type in "AO Smith Corporation" and you can get links with the entire history of the company.
Bama31 #430005 08/21/19 06:47 PM
Bama31 Offline OP
Thanks again. I was able to make out the rest of the markings after a little scotch brite and wetting it with rubbing alcohol. I believe it reads: AOS 5/28/31 N-4 SP
Thanks much,
Ralph
"Roll Tide"
